Old 10-29-2016, 12:34 PM
spdbrake spdbrake is offline
Yup that will work. You'll be left with what appears to be a standard hub w/ studs protruding. Rotor hat will still be installed. One - Two studs may come out with Pin drive nut as you remove them. no big deal. Just clean the threads in the hub and stud w/ Carb, Contact, or Brake cleaner and reinstall the stud to the hub using Loctite 272 (Red). Do not put Loctite on the area of threads where the Pin Drive nuts mate.
