Old 11-02-2016, 08:14 AM
cycleguy55's Avatar
I have been looking at making a set using these rebuildable units.
EMF Rod End, Small 3/4" Shank Heim Joint
Looking at making some CNC billet front and rear lower control arms for my CR at some point.
I've had requests for arms in the past but they are a fair bit of work to make in 4130 tube. One of my concerns about making them for others and why I have refused is engineering compliance. While I'm confident in my own welding and design I'd worry about supplying the parts to someone else. There are a lot of variables. Once a CNC program is written however it should be straightforward to make consistent accurate arms that I can get an engineer to sign off.
While there are minor differences between EMF and Spohn rod ends / pivot joints (e.g. Spohn has machined slots on the lock ring for the set screw, while EMF requires you to drill the lock ring) EMF rod ends and Spohn Del-Sphere pivot joints are very similar in concept and execution. Both seem to be excellent products for use in control arms.
Brian
