Originally Posted by MikeFromPerth
Does your fly by wire throttle setup still look like it did in the photos above, or is there a new arrangement?
hi mike
no changed it the reason been i moved the master cylinders out further thru the firewall to gain some more leg room unfortunately there was not enough room to mount the dbw unit .
it's now mounted on the side i will snap a picture for you if you like .
cheers dean
