Mike K has spent countless hours designing and perfecting the 289 chassis using all the known plans along with first hand measurement.
WELL DONE MIKE!
From Mike;
Modeled it all in CAD based on the data I had, then rendered it up with some color. Every item used in it is exact to the brackets, tabs, and profiles that the chassis will be built with. So it is an accurate representation. I have the 427 as well, but I need to add in the rollbar, then re-render. The 427's are already available and out there! Will follow up with the 427 after I redo it in the next couple days.
My next frame will be a MK Frame...
