I have a dizzy where the vacuum line connect there is a threaded union. If you unscrew this you can put in spacers to limit vacuum advance and also change springs to alter the vacuum it needs for advance. After reading a great article on vacuum advance, I now use manifold vacuum only. It idles much better and has better throttle response.
JD
