Snake,
Assuming you have an electrical guage, take the matching sending unit and attach it - screw it in to the left front side of the block. You may have to have an adapter or extension from the block so that the sender fits.
You then wire the sending unit directly to the "S" terminal on the back of the guage. You will then hook up an ignition wire (hot-key on only) to the "I" terminal. "G" goes to ground. There you have it.
Do not put teflon tape or goo on the sending unit threads. The sending unit has to ground at the block.
Wilf: Honestly, I just never gave the reinforced line a thought! I find that a huge brain fade on my part! In fact I was going through one of my hi-tech racing catalogs yesterday for parts on our new E-M Cobra we're building. Right there in the middle of the magazine they show a set of the most awesome guages I have ever seen, and lo and behold, they have the braided
Oil pressure line hooked up!
Oh well! Once again I prove the old addage wrong! You can teach an Ol' Dog new tricks! Thank you again for that one!
Just a side note to Petek: Jim thinks your his best buddy right now! He loves the schematic you sent. It will be done!
DV -- We need your support and presence at the Fling. 300 Cobras ARE going to be one awesome sight to see!
Are you registered?
