VE Vapor canister plumbing
I need help with the plumbing of the fuel vapor canister from a VE Commodore. The two lines to the left are marked, the large one PURGE, so I assume this go's to the purge control solenoid valve located near the throttle body (LS 3 engine)
The other is marked TANK so that go's to the fuel tank probably up high on the filler neck. But the large flexible corrugated line ??? not sure.
Appreciate any help with this one.
