Originally Posted by blykins
Personally, knowing all that I know, I wouldn't consider an aluminum block a bragging right, but I could see where it could be taken that way. Same way as bragging about having a "6-speed".
By the way, RK, this post wasn't an argument to your points, but just trying to clarify some things out there that could be really considered rumors, as you call them.
No worries.
While you, as an engine builder, don't think running an aluminum block is a bragging right, the consumer still does. And when you go to sell your Cobra, the buyer's perception is that the alloy block is better. Why? It costs more and it removes about 100 lbs from the front end. Until buyer's perceptions change, it will continue to be an issue when you go to sell your Cobra.
Are the OEM foundries different from the foundries that cast the alloy FE blocks? There can't be that many foundries left in our country that can make these things anymore. The FE block has been around for 50 years, not much has changed, so it's not like these foundries are inventing a new iPhone or the newest flu vaccine.
