11-18-2016, 02:21 PM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by blykins
Can I disguise my voice?
EDITED....
I was assuming Lippy was talking in my Hillbilly vernacular....which would mean that 4% isn't *anything*.
Power to weight ratios are laughable at the level of a high horsepower Cobra. With 600 hp, who here can tell if they are carrying a passenger at WOT?
Where the difference may lie is the weight distribution. I had both a stroked 351W and a 428 FE in my Cobra and, IMO, the difference wasn't noticeable. However, to be fair, I didn't get much seat time before I got bored and sold it....
If the weight difference was out there hanging off the oil cooler, I could see some value in lightening the load. However, with the engine's weight so far behind the front axle centerline, I just can't see the advantage unless you were on a road course. And even then, to really find the ragged edge of each setup, you'd probably need more than a conventional wet sump setup....
Absolutely I can tell when I'm carrying a passenger, same as I can tell if I have a 1/4 or a full fuel cell. It's not the weight I feel, but the increased traction from the higher rear percentage. To be clear, I'm talking about on the street with limited traction. I've never had a problem with forward bite on road courses and prefer less rear percentage than I run on the street.
