Ok, some data I found from the FE forum since I don't have any dyno sheets to prove my point.
From Dave Shoe (speaking to Robert Pond):
"The horsepower differences between iron nand aluminum blocks have been repeatedly characterized by Robert Pond, though I am necessarily distorting his claims because I lack sufficient experience to fully comprehend all his findings. He has been particularly interested in horsepower gains as small as a single horsepower, as his Stock Eliminator racing engines are constrained in the modifications which are allowed. I've spoken to Robert a little bit about "free horsepower", and he strongly contends that the block, all by itself, can provide dozens of free horsepower between the 600 to 1000 horsepower levels, just by its cylinder rigidity characteristics."
From Barry R, speaking of his Federal Mogul days:
"Well - - I can add a little fuel to the fire.
I supply rings and bearings to a large percentage of Pro Stock, Cup, and fastest street car competitors. In virtually 100% of situations where the weight is not critical (meaning that they would have to add ballast to offset any weight benefit from aluminum to meet a mandated minimum) these competitors ALL run an iron block of some sort.
Iron blocks simply make more power. Every time. The commonly bandied about number is somewhere between 15 and 30 - depending on the power level and the particular engine in question. Big beefy billet caps on aluminum blocks are kinda like a super strong steel lid on a cardboard box - when they're stronger than the parent material the value is limited. Ultimate power handling potential is not an issue - both materials have been proven at levels beyond anything feasable in an FE (I have seen numbers near 3000HP).
When properly prepped and designed, neither material will show bearing issues - but aluminum does require tighter cold clearances. Fuel motors don't count - - repairability is more important than the nominal power difference when you're at that level. The sole benefits to an aluminum block are identical to those of aluminum heads - weight ease of modification and repairability."
