Originally Posted by olddog
At 10 psi boost you will need roughly 2/3 more fuel. Make sure your fuel pump and lines can supply the fuel. It gets ugly if you suddenly go lean at full throttle high rpm.
I appreciate the heads up, but this isn't what I'm looking for. I'm very aware of the additional fuel requirements. The question wasn't "what all is needed to supercharge this car?" It was "what SPECIAL parts are needed?" I.e. A one-off bracket that moves the alternator because of the tight space in the Cobra engine compartment, etc.
