Old 12-14-2016, 01:57 AM
Riverside racer Riverside racer is offline
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
I have two types of Clevis extensions for both clutch and brake . One which will put the pedal 20mm Closer and the other which does 40mm. First check if you have enough free space on the floor to allow this mod and then also if the throttle pedal will not be too deep to allow easy foot movement .
Ross
