As you're installing the windage tray, turn the crank over once and make sure there are no interferences. If something hits the tray, you'll have to shim it with a washer or two between tray and cap. Then, when you install the pan, check it again. The crank scraper on my Canton pan pushed the tray into the crank. Had to clearance the crank scraper with a die grinder for clearance.
