Old 12-18-2016, 05:01 PM
DanEC's Avatar
DanEC DanEC is offline
I had a lot of related issues with my ERA when I was getting it up and running. I suspect that basically the red light circuit isn't exciting the voltage regulator into "regulating" and since the alternator isn't hearing of a demand from the VR, it's not charging above the default 12V.
It's a confounding problem to resolve. Even when my charging light bulb was burning I didn't have enough resistance to excite the VR and ERA had to rig up a resistor to work in parallel with the bulb to create enough circuit resistance. But since yours was working before something has changed. I understand that bench checks of alternators is sort of an iffy thing. They may produce 12 V but will they spool up to the 13.5 to 14 V as demand is put on the charging system? You may have to try another alternator but most dealers are hesitant to take back electrical parts that have been installed.
ERA 782 Running
