You want a thin
oil when you first start the motor and one that thicken up a little when the motor reaches operating temperature. Hence 5-30w
If you motor was build with tight bearing tolerance you would need a thin
oil. A motor with loose (race) tolerance would need a thick
oil.
Dwight
