Old 12-31-2016, 01:32 PM
eschaider's Avatar
Originally Posted by airboat1 View Post
I recently purchased an E-M 2005 built cobra with a 351W engine built by a custom shop out of state. It's winter here in upstate New York and I'd like to change the oil to eliminate any potential corrosion while it sits for the next 4 months and have it ready for the summer when it finally gets here.
I wouldn't worry about any corrosion, Steve. As luck would have it, absent significant engine failures, the oil is inside the engine and once the engine has been started the entire interior is coated with an oil finish. Moreover, unless you disassemble and wash the engine parts it is essentially unheard of for the oil finished components inside the engine to rust over a winter — even if the vehicle were left exposed to the elements outdoors.
What is the best blend and grade oil I should use. I only plan to run it in the warm weather so I don't feel I need a dual "w" blend. Also should I use a synthetic blend, full synthetic or non synthetic oil. Can I switch either way on oils without creating a problem? I have no idea what oil is in it, pulling the stick the oil is a light amber. The engine has less than 1500 miles on it. The car also has two side by side Fram Racing filters in it. I have read quite a bit on oils and still would like someone's opinion.
Thanks,
Steve
The best thing to do is to ask the builder who built your engine what oil he wants you to use. He is the only one who knows, with certainty, how your engine was assembled and therefore what it will require.
Ed
