Old 12-31-2016, 02:40 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Originally Posted by airboat1 View Post
I only plan to run it in the warm weather so I don't feel I need a dual "w" blend.
You should run a "W" blend oil. It's not just the ambient temperature that you need to worry about. It is the difference between the ambient temp and operating temp. Even if it is 100 degrees outside, a straight weight oil will be too thick to adequately flow if it is the correct weight/thickness to provide the right lubrication at operating temp.
