Old 12-31-2016, 10:11 PM
DanEC's Avatar
DanEC DanEC is offline
Troy - I'll see if I can find my wheel info. The backspace on the wheels should be comparable - just the distance from outside edge of rim to the inside hub surface. But the adaptor thickness could be different between the two wheels - assuming they are 5-pin with an adaptor. If they are 6-pin then they can't be easily compared to my 5-pins. Who sells those - Trigo, Vintage, ?
ERA 782 Running
