Thread: TR6060 to LS3
Old 01-05-2017, 04:46 AM
Cobrakiller's Avatar
Cobrakiller Cobrakiller is offline
Slave cylinder part # for the the VE series 2 - VF is GM 92251476 This suits the TR6060 with the dual mass clutch setup as in the posts above.
VE series 1 slave cylinder part # is GM 92227219 this is approx. 40mm longer than the series 2 setup and is for the single plate non dual mass setup LS7 clutch etc. There is very little info around on these differences, might help someone else with there TR6060 dilemas. I used the factory clutch pedal and master cylinder. Note the spline is the full length on input shaft in this pic of a series 1 TR6060.
