Old 01-05-2017, 03:58 PM
Jim Vander Wal Jim Vander Wal is offline
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I fixed mine. Chassis #1855 and 2584. Quite simple actually, I took 'em out. Saves aggravation, the expectation that they'll work and the weight.
If you're in an emergency the time it takes to realize that the e-brake has failed as well is time not well spent. These might be better called "parking brakes" but even that is an overestimation of their performance.
For parking I use wood as Blas has recommended or fold-up chocks with a string to facilitate retrieval.
The driveshaft mounted brakes collect all the grime from the engine and road which helps with the slip and keeps the disk from rusting.
Good luck.
Jim
