Engine shot
Just got an "old school" air cleaner for the Backdraft. The mounting screw was too long, so there is a socket spacer for now. Just thought I would point that out before someone else did! I will be cutting it to correct length. Remember when you are doing this to thread a bolt on below the cut. Make the cut, clean it up with a file, then unscrew the bolt. If you have a crooked thread, that will generally straighten it up and make the wing nut slide right on.
