The more positive castor you add the more the self centering effect on the steering in a straight line. This also increases the effort needed at the wheel.7+ castor is fairly normal setup on modern steering systems with power steering. Check what castor you have now and increase this until you get the right feel.Any adjustment will also effect your camber too, steering geometry is a compromise.
