Kevin,
Don't use Blue Hylomar - it is rubbish. I use Threebond liquid gasket 1209 (I think) the grey stuff. It is basically the same as the Motorcraft TA-31 mentioned in above posts. Also, I use Evans Waterless coolant in my Shelby FE stroker. This is far superior to water/glycol mix because it drastically reduces system pressure when the engine gets up to temperature - hence no leaks. PM me if you need further info. I'm in UK like you
Regards
Stuart
