As for the build details, it is .30 over 302 with a Trick Flow cam, .574 lift with roller rockers. AFR 185 heads with heavy duty springs for the cam. Stock rods (well, ARP rod bolts) and stock crank. Edelbrock RPM Air Gap intake with a Holley Double Pumper carb. MSD Pro billet distributor with steel distributor gear. MSD 6AL ignition with MSD Master Blaster coil. Tremec 5 speed with aluminum bell housing and a King Cobra clutch. With the 3.91 rear it is a very streetable car. Plenty of moxie without being so hair trigger my wife won't drive it. (she is not a "car girl" but does insist her daily driver has a manual transmission. Honda Civic Si with a 6 speed manual is actually a pretty fun car to drive around as a grocery getter) I didn't build the car, but got it with under 5,000 miles on it as a 50th Birthday present. It is a hoot!
