  #26 (permalink)
Old 01-19-2017, 06:54 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
With that leaf spring wrapped in the nastiest stuff known to man! I had the last N.O.S. leaf spring from AC when Autokraft took over all of the spares and the stuff that the spring is wrapped in gets all over everything! I have never seen such insidious, creeping black gunk in my life!
That is one thing we did NOT replicate with the Superformance MK II cars!
Well, it keeps water out and lubricant in. Leafsprings can wear quite quickly with grit and water between the leaves.
I wrapped mine with the original materials. First the spring is coated with a thick covering of OGL (Outside Gear Lubricant) grease, same stuff they use on truck fifth wheels. Then it is tightly wrapped with Denso tape, a cloth-based sticky tape, still available exactly as AC used it. Several other more upmarket manufacturers used it, too - Bentley, Rolls Royce etc. It is wrapped so that it can be held in place by just one metal strap fastener. Yes, it's not nice, but...
Roger
