Originally Posted by spdbrake
I definitely would be interested.
Mine are unequal as far a spacing off the body (left side does not run quite parallel to body) and turnout tip clocking is miss-matched L to R. (being #53 it is probably not surprising).
I would like some better mufflers.
Flat white if you have it available.
That correction needs to be done on the car. We will only be offering to factory flanged pipes (late style) as that is the closest we can get to consistency.
The coffin concept is good, but I'm hoping to not have the shipping outprice the service. Believe it or not we received a set of pipes in a ton of bubble wrap once with a plastic wrap around that and they came through mint. I just think that was a one time opportunity though.
I'm going to look into some type of hard case that can be returned perhaps.
