Old 01-19-2017, 07:28 PM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
Mark, it's definitely not a direct fit. The inlets for the lines are at a slight angle, so the line will have to be bent down a little. I don't think you will have to completely rebend the lines though. Also the switch location is not at the end. It looks like it was shipped with a plug in one of the holes that will have to be removed for the switch. Either that, or go with a mechanical switch on the pedal. Here's some links to a couple pics. If you search for the BA part new number, you'll see it's the same.
https://www.dropbox.com/s/wezmqpul41...%20PM.jpg?dl=0
https://www.dropbox.com/s/96pptm39yp...%20PM.jpg?dl=0
