Yep. I will have a better idea when all the timber is out, but I will find somewhere under the tray to hide them.
Just ordered 20 tie down turn buckles, also a 10t snatch block, so I can run the winch cable down along the tray bed if I manage to get a second Corona on the bed.
My thinking is to make some form of steel raiser that will let me put a Corona on backward, lift the front and put the raisers under the wheels, then get a second Corona on the back with the nose under the first car.
Originally Posted by Aussie Mike
Good work Dave
From the look of the tailgate it should be easy enough to modify to add a door to slide your aluminum ramps underneath. You would want to make some sort of locking mechanism to hook them to the back of the truck too.
Cruising in 5th
