Old 01-23-2017, 01:08 PM
DMXF DMXF is offline
Original Shelby Owner
Cobra Make, Engine: 31XX Car
Default 428 oil pressure
Assuming they missed high oil pressure on the dyno, sounds like you have the wrong oil pump installed. I had a 428 done a few years ago and during priming my engine guy found oil pressure too high. It turned out we had a 427 pump installed which has a stiffer spring because of the block pressure relief and after swapping in the correct 428 pump everything was fine
