Old 01-23-2017, 05:40 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
As DXMF said, the relief spring in the oil pump, which opens a valve to dump excess oil back into the oil pan at a PSI determined by the strength of that spring, may for some reason be too strong and not allow that valve to open below 70psi, even in a brand new Mellings (great choice, BTW!).
Perhaps a call to tech support at Mellings could help figure that out and even allow you to get the correct spring to custom set a max psi to suit your engine builder?
Just a thought.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
