Clutch or ??
And the fun begins again.............Out of the blue, my car will not shift into any gear with the car running. I can turn the car off and I'm able to shift into reverse. With the clutch engaged, I'll restart the the car and it want to go backwards with the dang clutch petal pressed to the stop. When the car warms up, the forward gears work but it grinds while trying to shift to reverse. No leaks, trans fluid level good. Does these cars use the same hydraulic reservoir
as the brakes? Any suggestions?
BDR
Roush 427R
Tremec 600 5 speed
Not sure what type of clutch I have
Car has less than 4K on it.
