Thread: Clutch or ??
Old 01-30-2017, 08:28 PM
GLS-BDR226 GLS-BDR226 is offline
Cobra Make, Engine: BDR, 302
I would guess as spdbrake suggests, it is probably either the clutch master or slave. Have someone look at the slave pushrod as you depress the clutch pedal. Also, check the slave for leaks. I've had to replace the slave a couple of times. Flushing and refilling annually with Wilwood racing brake fluid has helped. Heat shield from BDR on the clutch master has also helped.
