Thread: Clutch or ??
Old 02-01-2017, 05:11 PM
spdbrake spdbrake is offline
If you have a alum master cyl heat shield on the masters, removing it will make access easier. Just put one nut back on the brake master stud to keep it in place.
Pull the cotter pin and clevis pin at the clutch pedal.
Using your left hand and a 1/2" or 12mm boxend (depending on your build) will get you on the clutch master nuts. Another person inside the car can remove the bolts while you hold.
