Old 02-08-2017, 01:20 PM
*13*'s Avatar
*13* *13* is offline
I'll check these things. Thanks. I think I need to invest in a temp gun, as well. It's all strange that it ran fine for the first couple weeks that I had it & then started getting hot.
The clutch fan wasn't operating properly. The thermo spring wasn't even connected. Now with the fan clutch operating properly it still sits higher & than it did, originally. When at highway speeds it runs a little hotter then, cools back off a bit when at lower speeds. the temp sender is new.
The timing should be good but, maybe the advance isn't pulling properly.
The radiator tank is easily the highest point in the system. sitting on an incline might be worth a try to double check for any air in the system.
ERA FIA 2088
