Thread: Lack of air
Old 02-14-2017, 04:10 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Grubby View Post
It seems really unlikely it is starved for air at idle. At wide open throttle it might need 850 cfm at idle it would need only a few hundred.
I am sure closing the hood is a clue.
John
If the engine is losing this amount of rpm at idle when the hood is shut, then the engine would be starving for air at anytime above idle speed.
I would remove the aircleaner, and see what it does then.
You could also have a hot air issue that makes the carb mixture different at hot idle.
