Old 02-15-2017, 03:13 PM
*13*'s Avatar
*13* *13* is offline
Originally Posted by cycleguy55 View Post
My BBF 460 came w/o a thermostat. I bought and installed a high flow thermostat that had a small poppet valve in the plate to allow air to escape. I also drilled a couple of extra 3/16" holes in the plate to allow air through, though it does take longer to warm up than I'd like (especially when the weather is cool).
Check out the tech tips at https://www.stewartcomponents.com/in...formation_id=6
I did the same on my small block to get some more coolant flow at startup. The thermostat sits a few inches off the block & that first opening takes a bit longer. Thanks for the reminder. I'll keep it as a possibility if problems persist.
ERA FIA 2088
