Old 02-16-2017, 02:31 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by Paintwerks View Post
The system is referred to as 'Bimodal'. The Xforce 'Varex' servo-adjustable bimodal mufflers are what you want. That said, with the Cobra's limited undercar space, I am not sure which of their units would fit?
Varex Mufflers
There is also the issue of legality. Despite HSV and Aston Martin (that I know of) having factory fitted, ADR approved bimodal exhaust systems, apparently to add a bimodal muffler to a vehicle that never had it from new is illegal. I guess you could get the car engineered with it after fitting and that would comply?
I had a look at the Varex a while ago too. The problem is their servo mechanism protrudes out the top a fair bit and where I wanted to put them under the Cobra floor, there just wasn't enough room.
I've seen a cobra at the Nationals that has the valve only option and diverts between a "loud" side non-mufflered exit and a "not so loud" rear mufflered exit.
cheers Gregg
