Need Help with Transmission Install
I have tried twice to get the transmission in my Cobra and was unsuccessful both times. It will go until it needs another inch and then stops.
I have the back of the engine raised, and made two pins by cutting off the bolt heads per Doug at ERA. These are in the top two holes of the bell housing.
I have an aluminum FE, Quick Time bell, McLeod twin disc clutch, and Tremec TKO 600. Prior to both install attempts I aligned everything carefully with the alignment pin furnished with the clutch.
Is there anyone in the a north Dallas area that would be willing to come by and help? My location is near Royal and 75.
Thanks a bunch.
Chris
