Hey Jaydee,
I am currently in the process of building an ICCARS AC Cobra for a melbourne customer and we will be getting the full compliance side of things sorted here in S.A. then the new owner will be able to do a "mechanical inspection" in a licensed garage over in Victoria and do the transfer into his name etc.. He will not have to go through Vic roads to get his car registered there.
The only issue you may have is if you have used an older engine such as a windsor V8 then you may run into trouble, as they are not allowing windsor's for compliance in Victoria other than through an IM 240 emission cycle test. Check this with your engineer but if you have a later model engine such as a BF Boss modular V8 motor or LSA engine then get it complied here prior to going to Vic.
Hope this helps.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
