Jag Front end
Hi All,
I have series 1 uprights on the front with the narrower stub axle inducing flex under hard braking. Want to freshen up the front end including upgrading to the later vertical link\upright\hub carrier\knuckle (whatever you want to call it).
Wondering if anyone has any of the later vertical links sitting on the shelf, and can anyone confirm they are the same part up to the last of the series 3 up to 1992 and all xjs?
Im finding CAC1100 and CAC1101 as the part numbers - if anyone has one they can confirm that would be good. Part number is just under the top ball joint on the inside.
Thanks in advance for any help.
