Hi Guys,I want to install a PVC set up on my 2- 4 barrel side oiler. My questions are I would like to install a catch can with this setup and can I drain the catch can back to the
oil pan? I recently installed a Aviaid 10 qt
oil pan with provisions welded in the top for 3/8 and 1/2 hoses. They are blocked off now but are easily removable. Another question is where is the best location for the vacuum source (base of one of the carbs)? There is a bolt on plate at the rear of the engine that looks like a draft tube would go there. Could the PCV valve be installed there instead of the valve cover? I hate to drill into my new Cobra valve covers. Finally there are so many PVC Valves is there any particular one I should consider?
Thanks for your time.
