Old 02-21-2017, 08:22 AM
crawleyscobra's Avatar
crawleyscobra crawleyscobra is offline
Cobra Make, Engine: Factory Five MKIII, 427W
I made a cross over vent tube like Holley makes, which made a big improvement on mine. Took a small copper tube (forget the size) and shaped it to fit between the two vent tubes. Then drilled small vent holes on the top side. The tube snugly slides into the carbs vent tubes and the top of the air cleaner keeps it from coming out even if it vibtrates loose.
FFR6682 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475hp/500lbs), TKO600, Power Steering/Brakes, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Cobra rotors w/calipers, Nitto NT05-255/40R17-Front, 315/35R17-rear,3.55 IRS.
