Old 02-21-2017, 09:49 AM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Sounds kind of like a solution in need of a problem. Unless you have reason to believe otherwise, I suspect in a properly vented system you're just not going to get much, I sure don't nor do several I know of. Mine vents to the carb vacuum fitting from the intake mounted valve and I get little or no vapor.
The older I get, the faster I was.
