Old 02-22-2017, 02:00 PM
snakesaway's Avatar
snakesaway snakesaway is offline
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Default Squeak from rear of car.
Hi all,
I have weird squeak coming from the rear of the car when I first start driving. the squeak increases in frequency as I increase speed, and it goes away or is masked by louder road noise as I increase speed. It sounds like rotational noise/wheel bearings as opposed to a squeaky bush or suspension squeak. I haven't noticed it as I pull up to or away from lights. It appears to go away with driving but if the car is left sitting for say an hour the noise will come back again, when the car is first moved in either forward or reverse.
Has anyone had similar problems? If it is wheel bearings are they easy to change I have had a look on the net and it looks relatively easy its just measuring the float/pre load that might be tricky.
Andrew
