Thread: New Build
  #579 (permalink)
Old 02-25-2017, 01:36 PM
BJ's Snake's Avatar
BJ's Snake BJ's Snake is offline
Default I wish!
Originally Posted by Paintwerks View Post
It really depends how far you want to take it.
Colour choice including whether the car will be a solid or metallic will determine the cost of materials, as would the inclusion of painted-on stripes. But for all intents and purposes, using high quality materials such as PPG or Glasurit, there's anywhere between $2000-3500 in materials alone.
Most quality bodyshops (including mine) charge between $100-120 per hour which we believe is fair and reasonable given the cost of a skilled and experienced trades person can easily eclipse $70 per hour alone. Then you factor in overheads, depreciation and g-d forbid the shop makes a little profit inside that hourly rate, too.
Even on a nicely constructed Pace body, there'd still be anywhere between 40-70 hours labour in the job, which factors disassembly, cleaning/decontamination, initial prep/sanding, fixing of any lows and discrepancies (yes, they do exist on the body to certain extents depending on when it was manufactured), masking, priming, block and hand sanding the car in a minimum of 3 different grits (incl. wet sanding), cleaning/decontamination, masking, surfacing/sealing, painting/baking, denibbing/polishing and reassembly. So there's $4000-7000 on average in labour.
Flowcoating additional clearcoat following the original application of clearcoat would be considered an extra-cost addition.
Add GST and as you can see, painting of a Pace would typically cost between $6,600 to $11K. There will obviously be some variation in that, but I'd say Guy was pretty much on the money with the job on average typically costing between $7-8K. That would be for a high quality result in metallic which would include painted-on full length stripes. Number rondelles and/or rookie stripes would be an extra cost option.
Hope this helps to clarify people's understanding/expectations of what it costs to paint the car.
Sime
Interesting read there Sime.
I think you are on the money as well, I am getting quotes of between 15 and 18 grand to paint my FIA.
I, for the life of me cannot find the justification in those prices.
10k should stop it I reckon.
What am I missing here.
289 FIA Cobras RULE!
