Old 02-28-2017, 02:42 AM
aussiecoupe aussiecoupe is offline
Cobra Make, Engine: Harrison , 5lt Ford . FF GTM 6LT GMH
Default pedals
Hi I have replaced the ford pedal box for Willwood pedals on a couple of Cobras . the fire wall is 3mm thick and while you have the body off fit brackets for the upper mount .
For compliance fit float caps which you can wire in for fluid low level . For the brake switch best put one in the brake line .
Hope this helps
Warwick.
