Originally Posted by 120mm
Included in that question is the query, is it worth it to just chuck the stock bellhousing and go with a Quicktime for $700?
I have a used Lakewood for an FE, great condition, already cut at the bottom for a Cobra, if you are interested. The only reason I switched to a Quicktime was that the Lakewood won't clear the frame rails on a CSX so you have to pull the engine to do any clutch work. The Quicktime is a bit smaller and will clear the frame with the engine in the car (although not easily
Anyway, PM me if you are interested. I've been meaning to sell it so I can clear up some garage shelf space.
www.partskeeper.com
