Thanks for your thoughts, guys.
I have ceramic coated headers, but was also suspecting the same solution. Insulating the steering column might be a simpler and a quick way to determine IF heat/expansion is the source of the symptom.
Now,....off to search for a means to insulate the ¾" shaft which has 5/8" clearance from the header.
Any suggestions anyone?
Thanks to all!
