Originally Posted by 120mm
Right now, the two most common stroker "kits" are 4.125 or 4.250 cranks, which result with approximately 431 or 445 c.i. displacement.
Among really smart, gifted, and talented FE engine builders, there is a split of opinion as to whether a shorter stroke, which will reduce piston speed, will make an engine "revvier." It has been debated on here, and the FE Forum more than a few times, and both sides are firmly entrenched in their respective positions. FWIW, I opted for the 4.125 SCAT crank for my 428 stroker kit. The longer stroke might make a little more power, but the shorter stroke makes more fun (others will steadfastly disagree).
