03-11-2017, 06:13 AM
AR
Originally Posted by wolf k
Got it I think, just to be clear, you removed the bushing and shimmed between the OD of the bushing and the ID of the column? the bushing must be split then, to be able to shrink it.
I am not able to lay eyes on at the moment it to confirm.
Yes, it was a piece of rectangular shim stock to fit between the bushing and the ID of the column. The original bushing is split. Here is an exchange with Bob on this issue a couple years ago. Not a lot of help to you but may give you some insight to the issue.
Steering column play
Interesting, nobody else having turn signal switch issues, I must have a weak one. Where did you source your new switch?
Here is where I got mine.
VW Turn Signal Switch, 1966-67 Type 1, (Dimmer Switch Included!), 141-953-517F BK - Aircooled.Net VW Parts
It seems that I ordered from another source first and it was a real piece of garbage. There are apparently a lot of sources for new ones and they range from fairly nice to down right horrible. As a matter of fact I would call Bob first and ask if they have found a current source for these that they feel are good quality. I think I called this place up and talked to them and had them go through a bunch of them trying to find one they would actually sell to a family member with a clear conscious. It seems I remember there was a great variety in pricing also. The reason ERA couldn't help me out with a switch was because they said they didn't have a supplier for them at the time that they felt confident in the quality of them. Maybe they have found one now.
Good luck
